- Joined
- Sep 30, 2013
- Messages
- 292
- Points
- 121
Had a similar issue on an Alfa 33; was traced to the strut bearing assembly - it was seized.
Needs to be correctly aligned too.
OMG another controversy. ePER agrees with Jock so maybe there are alternative setups.? Look Mum, no teeth!
This will expose any steering rack issues. It will not expose a failed top bearing, because lifting the car unloads the strut tops.lift both wheels off the ground
keys in the ignition take the steering lock off
push and pull on the tyre to move the steering from lock to lock
is it smooth in both directions
turn the steering wheel while someone watches the wheels are the smooth no jumping
Have you a "knowledgeable" pal at work? Could the two of you take the car to this yard then one of you get out and watch that N/S/F wheel as you drive around in circles. The reaction you're describing seems quite defined so I'd imagine if someone who knows about cars was watching the wheel and you perhaps shouted out or raised a hand as you feel the effect perhaps the person observing will see something?I'll have another look at work next week.
I did take it up to a large yard my work uses this morning to see if I could pinpoint it a bit more.
Problem is only turning left, right is absolutely fine.
Turn the steering wheel around 40 degrees left, it turns fine.
Turn it 41 degrees, and that's when the car suddenly pulls to the left.
No sensation through steering wheel itself, just the sudden lurch to the left.
If I keep it around the same point, and literally try and keep it on the point when it happens, I can feel the front end trying to break left and right.....almost feels like the wheels are twitching left and right.....its just at that one point......gets worse the faster it goes....again, nothing through the steering wheel itself.
Next I went round in left hand circles with my foot on the brake......absolutely fine. Drove straight, and turned left while braking.....no twitching or pulling.....so when brakes are on, it obviously stops the movement wherever it is.
Had both wheels off ground, can turn both ways smoothly by hand, and with someone turning steering wheel, smooth both ways.
Hi Dave. As I'm sure you know, struts today tend to be retained into the wing mounting with a single nut and plate which stop the strut falling out when the car is jacked up. Of course you can undo this nut and not suffer any consequence other than that the strut will drop down if you jack the wheel clear of the ground. The next hut down - No 6 on your illustration - is the "dangerous" one as it's securing the top mount and top spring retainer to the damper rod. It's this one which causes the loss of teeth and need for fresh underpants if it's undone without the spring being restrained in some way.OMG another controversy. ePER agrees with Jock so maybe there are alternative setups.
My front strut had a large nut (6) with a machined rebate that fits into the spring top (8). The nut is not flanged like the one shown here and goes UNDER the bearing. The hole in my spring top (8) is about 1" diameter and would rattle about if fitted as ePER shows.
On mine it's as follows -
Bump stop - Spring - Spring top plate - Special retaining nut - Thrust bearing/rubber mount - Safety retainer and final nyloc nut. The last two are fitted after the spring and and strut are put into the car.
in left hand corners. The off side does most of the steering and is most loadedCould the two of you take the car to this yard then one of you get out and watch that N/S/F wheel as you drive around in circles. The reaction you're describing seems quite defined so I'd imagine if someone who knows about cars was watching the wheel and you perhaps shouted out or raised a hand as you feel the effect perhaps the person observing will see something?
this is progress.I'll have another look at work next week.
unless its assembled like this. Its not as Fiat intended. And will not work as intended
I have checked all variations, And the later 500's, they are all the same, including 100hp and 4x4
everything under the top hat is under compression, unless some dodgy shortened springs have been fitted
Obviously coil overs are different
nut 6 needs a spring compress fitted first.
Yup, did both struts on our Panda - 2010 1.2 Eco Dynamic - Exactly as shown in Koalar's illustration.In December, I replaced both front shockers on my 2009 1.2 Eleganza and they were assembled as per Koalar's pic.
unlikely to be the EPS in my opinion (Read guess)It could very much be caused by the EPS, respectively damaged torque sensor. This is one of their manifestation, to pull left. Try to connect to the EPS computer, see if there are errors stored. Heavy impact does mess up the torque sensor. It is sensible to theese 2 things: bad voltage (low) and impact.
