General Car Keys. a bit loose.
Mike57
Loftus, Cleveland.
Guys can you help.
My car keys are starting to get a bit awkward to open the door locks ! what could cause this ?
What if I used a bit of wd40 in the key holes !
I'm well and truly stumped :confused:
ps my car does not have a fob.
Will this staff work on locks that are sticky due to frost? I have a bit of problem with my driver side lock at the moment if temperature below 0. I suspect I have some humidity in the lock and freezes up.
+1 i'd like to know if it'd help me or not as i too have such issues
tbh tho a little bit of lock lubricant cant help anyway
Ziggy
Till I get to Boro, at the mo I use a bit o wd40 that seems to work, but on a morning if the locks are frozen I squirt a bit o De-Icer in the key hole !
the WD displaces the WATER, - that's what freezes,
then the graphite is a lubricant should not be as weather dependant then,
If it's also a bit finnicky in the ignition barrel then it's likely to be a worn key..,
Charlie
ok thanks guys, I'll get some the next time I'm in middlesbrough. (Maplins)
any automotive locksmith will be able to help you mate... never had the same problem but i am pretty sure these experts will be able to do something.. i used this index when i had to get a spare key for my car.. if you call one of them and explain them the prob they will surely come and help.. hope it helps! cheers mate! http://www.carkeyadvice.com/united-kingdom-car-key-specialist-index
Hi Guys, I have bought some of this Graphite Lock Lube ( see pic)
Now last night I went fishing & when I got back to the car the drivers lock would not open so I put the key in the pass side and all the locks opened BUT not the drivers side, So I entered the car through thr pass side and tried to open my door with the little stick that opens the door but that would not move ! totally "stuck"
Just tried this morn and the lock still wont open so I got in by the pass side again and had to use a pair of pliers to "PULL" that stick up !
Could it just be sticking with the cold :confused:
http://
