Hello FF'ers!
Firstly, whoever can actually diagnose this issue correctly i will personally transfer £30 to your paypal if it fixes my car, as i would be so grateful for it
Background Info:
Brought the car Dec 2013, the only problem being the car revved high intermittently on idle (1800RPM).
Car started badly hesitating on accelerating about 4 months ago (got this fixed by changing the throttle body which was given to me by the previous owner of the car as he said this would also fix the high revs).
Fitted this new Throttle Body, but the part where it lets in and out air was snapped off (Plastic part on left hand side) So my friend just put tape over it and it honestly seemed fine. Ran the car again and POWER was back!
A week later, my car has developed an awful problem, it revs very very high on idle (ranging from 1800 - 2200RPM) However this is only when it warms up.
When warm it will pulse on idle (from 1800 to 2200RPM and back and forth). This led me to think it was something to do with the Tape on the Throttle Body. However i checked it and it looked okay.
Now i have a larger issue! When warm my car will lose all power and start juddering when i accelerate, however this only usually happens after it is warm and i have accelerated hard.. but once the problem starts it will pulse idle between 600rpm and 1100rpm (and sometimes cut out). A lot of the time the speedo will go dead and the revs will all die, even though the engine is running, if this makes sense (so the engine will randomly stop and then Regain revs on its own from 0RPM back to the pulsing Idle.)
Not really any smoke coming from the car however there is some white smoke now and again but I'm not too sure if this is just because its cold.
Ive changed spark plugs, leads and coil packs not long ago.
EXTRA INFO:
Sometimes if i go to start my car (once in every 10 start ups) it will tick over but not start (and then the key symbol will display) however if i just take the key out and then go to start again once the key symbol has gone off then it will start okay.
Recently, it has taken an extra second or two to actually fire the engine up.
NO Engine Management light on the dashboard.
My engine is a 1.2 8v.
My clutch is also vibrating A LOT when driving (I think this may be the flywheel) as when it idles it intermittently will make a squeeling noise (similar to a fan belt but not as loud) and when i press my clutch it will change to a ticking noise, but if i half press the clutch all the noise will disappear.
I may sound like a bit of an idiot as I'm not a mechanic but ive tried to explain everything as well as possible!
As said earlier if anyone can actually help me fix this issue i would be that grateful that i will transfer £30 to your paypal (paypal only no bank transfers).
I just want my Punto back on the road as i refuse to scrap her!
Thanks in advance,
Jayden
Background Info:
EXTRA INFO:
Thanks in advance,
Jayden
