L laddy7 New member Joined Mar 27, 2014 Messages 5 Points 4 Mar 27, 2014 #1 My 57 plate grande punto boot won't open, via the switch in the car or on my car key, Been told its the boot motor,…. anyone had this problem??
Lewisgroombridge Lewis G Joined Aug 15, 2012 Messages 182 Points 41 Location Hullbridge Mar 27, 2014 #2 Haven't had the problem.. But its on one of the stickies "common faults". Think it means either there is water on the mechanism and you need a new lock Check the fuse if there is one. Listen to see if there is any noise when you try and open it... If you can get it open clean the mechanism and see if that does it. If not a new lock may be required
Andy Monty Moderator Staff member Parked in the garage Written 10+ guides Joined Apr 30, 2006 Messages 16,902 Points 3,663 Location East Yorkshire Mar 27, 2014 #3 open boot from the inside https://www.fiatforum.com/grande-punto/270025-boot-problem.html?p=2760679 check boot catch check wiring loom in upper left corner of boot opening
K Kells53 New member Joined Jan 26, 2017 Messages 1 Points 0 Jan 26, 2017 #4 Hi guys new to the forum but the same problem. My question though is can anyone tell me how to open the boot when the electrical release fails?.
D digger58 Established member Joined Mar 25, 2007 Messages 1,657 Points 453 Location Limerick Jan 26, 2017 #5 Read Andy's post above. There is a link there. Probably water ingress in the lock. I stripped mine and eventually got it working.
