can anyone confirm if this works, or is it just my multi.[/quote]
Well Done :worship: :worship: :worship: Works on mine too. Only small problem is that even with the siren disabled, the hazard lights still flash if the alarm is triggered. If you're just opening the tailgate from outside using the key with the faulty sender* this is not a problem
. You can also start the engine ok but with the hazard lights flashing, driving away might confuse people. I seem to recall that under normal conditions once the alarm goes off (siren and flashing lights) it goes through three alarm cycles of about 1 minute each before disarming automatically so maybe it won't confuse them for too long. If the key in the ignition has a working remote, pressing it with the engine running disarms the alarm and turns off the flashers.
* I've got one `good' key and one that eats batteries; it drains a new set in about 8 hours. I discovered this after the keypress failed to unlock the doors. I opened them manually, set the alarm off and, as the batteries were flat and the remote didn't work, wasn't able to turn it off:yuck:
