the hobbler
Distinguished member
- Joined
- Jul 25, 2012
- Messages
- 4,421
- Points
- 1,112
I found it a lot easier to do this job with the doors off the car--especially if you are fitting "pattern" doors. My wife was very wise and said to me "why don't you do it on the spare bed". It was the perfect answer as (a) it is flat and therefore easier to work on and, (b) if you are fitting "pattern" door you will discover that not all the holes line up as they should--a fair bit of fettling is often required!---much easier to do in the comfort of the house with the door flat in front of you. One extra tip--once you have it 'dry-fitted' remove the bolts (I used 'button-head' Allen bolts) one-by-one and refit them with a touch of 'loc-tite'. The last thing you need is to hear a rattle in the door due to a bolt coming loose. The procedure is exactly as 'Vitesse' stated, but he is right, take it gently and be prepared to 'jiggle' parts into place.
