Hello all. I am really struggling to get the clutch to bleed on my 2016 Ducato 2.3 Euro 5. Long story - due to EGR issues, I had to remove the engine and gearbox after failing to undo the last nut of the EGR at the back of the engine. While the engine was out, I did the timing and auxiliary belts and tensioner pulleys. While at it, I opened up the belhousing and removed the clutch. As it looked in pretty good condition, I decided to put it all back together. Pretty much everything is back on the van, the engine started straight away, which I was very pleased. However, I just can get the clutch to bleed, no matter which way I try.
1. I have partially pushed out the clip at the slave cylinder, pulled out the hose connector about 2mm, depressed the clutch pedal, pushed the hose connector back in, then lifted the clutch pedal. I repeated this about 30 times. Fluid comes out of the bleed nipple.
2. I also tried to use a brake bleeding kit - which does suck out fluid through the nipple. Yet when I push back in the hose connector, there is still absolutely no pressure whatsoever on the clutch pedal, even if I pump it up and down a number of times on the pedal.
3. I have tried the above with the engine off and with the engine on. No difference.
4. The clutch and the brakes share the same reservoir on Ducato - apparently. Yet, although a fair bit of fluid has come out through the bleed nipple on the slave cylinder, the level of fluid in the brake reservoir seems to hardly have budged.
Am I missing something really obvious here, or as a complete coincidence, somehow the slave cylinder decided to completely go sometime between me taking the engine and gearbox out, and installing them back in? The clutch was working perfectly fine when I got started on removing the engine. Any hints much appreciated.
