- Joined
- Sep 14, 2009
- Messages
- 19,947
- Points
- 3,966
It does sound a bit odd, but, the accessory belt tensioner is a pig to fit and otherwise drops in at an angle, so it could get mangled.
If the cam belt did not actually fall off you might be ok. But teeth can strip (mine did)
Get the garage to check the cams and valves before they properly fit the new belt. Maybe fit the new belt and do a compression test before they box everything up.
I was happy with Shop4Parts so when you know what's needed give them a call.
