cinquerob
ok men, i know this. My engine is an 1108 SPI from a cinq sporting, can i put a copper head gasket?, with the SPI head no problem, what injectors are the best for this?, i think another problem is the istallation of the MF2, i need some photos or an sketch from this.8 valve hubs?
The 16v rods won't fit the 8v crank............
i don´t know this.
Is this engine MPI or SPI?
What you need to do differs in both cases, engine size, MPI/SPI.
Best bet, if going megasquirt without proper pistons, is Punto 75 engine, 16v rods and pistons.
Otherwise it's either 1108 with the VAD set up recreated (SPI head, one extra injector, MF2, FCD, etc.) -- this is a difficult way to go, at least as far as reliability is concerned.
Or, MPI 1108, special pistons (or other solution), any old aftermarket ECU.
Did I mention there was no easy, cheap, solution?
