Can an ECU forget everything?
bean
types his title here
North Devon
Hi
My friend has a 1.2 16v punto that's been led up in a barn for many years.
I wouldn't mind the engine etc to do a 16v swap on my cinq but he seems to think the ECU has had it as its been sat for so long and he will need the brown/red key to sort it which he doesn't have.
Is this correct?
Nath
I should imagine it will be OK, the immo code is held in the main fusebox but I guess you will have to sync the ECU to recognise the Cinq immo code.
Modern ECU's hold immobiliser data in a type of memory called EEPROM (Electrically Erasable Programmable Read Only Memory). This is non-volatile i.e. does loose data when the power goes off. It does not use batteries (like the "CMOS" in personal computers) so leaving the ECU off for a long time will NOT cause loss of immobiliser information. Of course, other components in the ECU could fail. Capacitors are a possible problem area as is corrosion in general.
HTH,
Robert G8RPI.
Oh that's interesting! Thanks for that!
Maybe the 16v conversion might be happening!
