Technical Camper won't drive
lp195757
Stewarton
My 34 year old campervan ticks over but won't drive changed fuel filter but don't know where fuel pump is to change it can anyone help me
Model
Elddis ducato
Year
1991
Mileage
74000
May I suggest that you look at the VIN plate, and quote the engine type, which will follow the heading "MOTORE".
Will that help me find location of fuel pump
Not directly, but it will help others who may be able to advise. Your initial post does not even indicate whether you ar talking about either a petrol, or a diesel engine.
If it is in fact a diesel engine, then the location of the injection pump should be evident if the metal pipes from the injectors are traced back to the pump.
Sorry about that it's a petrol engine and I have been looking at parts from Peugeot and ducato engines it has a carburettor and v assume it's a mechanical fuel pump I just can't find it. It's a high top van and old fiat ducato model
So,
Not located the VIN plate, or the V5c logbook for the engine details?
Thanks I've found it and ordered a new one hopefully that is my problem solved . Thanks for your help much obliged.
