Hi.
My new-to-me Multijet is in 139k miles and the original timing chain which is noisy.
I am trying to replace it but have got stuck at the point of timing the cams.
The flywheel locking tool has slotted in nicely but access to the front cam timing locking point is severely restricted by the turbo and I can’t get my locking tool in the rear one either because the inlet manifold is in the way.
I am not sure the cam is perfectly timed anyway because there are some timing discrepancy codes showing.
Can anyone give a little advice on how to lock both cams so I get the timing correct with the new chain?
Is there a set of locking tools that fit the panda without taking off the turbo and inlet manifold?
How the heck do you see anything down the hole to see if the cam recess is in the right place?
