Purchased a new 500 S&S last April and worked perfectly up until December 09. Engine management light came on, with stop start off, so was taken into the garage where they kept it for 3 or so days and then returned it to us.
I am sending a letter to the dealership to inform them that if the parts are not here within the next few weeks and or the problem is not resolved, I will be returning the car expecting a replacement car or full refund under the 1979 Consumer Act as the current car is "not fit for purpose"
Honest John said:And the supplier (in the case of a car the dealer principal of the dealership) must be sent a letter by recorded delivery detailing why the car has been rejected as not "of satisfactory quality". Case law (Rogers v/s Parrish 1987) has put a limit of 6 months on the time you can successfully reject a car and obtain a full refund, though lesser refunds, taking account of mileage covered, may be obtained outside that period. The price you pay compared to market value will be taken into account. So if you buy a cheap car on trade terms you cannot reject it under the Act.
i seem to remember getting flamed when i said that the start stop system was pointless technology and just something to go wrong![]()
Can't believe this thead of mine is still going! :slayer:
We've had the issue whereby the warning triangle light displayed and the car was very sluggish as a result of the Start&Stop stalling on a couple of occasions just two weeks after getting the car.
Took it in to the garage and have just been told it's as a result of keeping the clutch pressed for more than 10 seconds which then kicks in the Start&Stop.
From my understanding of the S'n'S system, this sounds like grade A bullsh*t. S'n'S shouldn't affect the mapping or throttle AFAIK.
Edit: 10 seconds clutch hold down for a hill start?? Are you holding the car on a hill with the footbrake for that long???
this is EXACTLY the issue I have, it's always when at a junction and I set off on a slight incline, on most occasions I'm not there long enough to put the hand break on but simply holding the car at biting point causes SS to fail. I can't see how having the clutch depressed for 10 seconds could cause it. I always sit at junctions with the clutch depressed, and it's for longer than 10 seconds (naughty I know!)
The garage told us that this is more likely to happen on hill starts which as we live on a hill is highly likely to happen again.
Obviously permanently disabling SS will cause tax issues and will void the warranty so we've been told to 'change our driving style and use the handbrake whenever we stop' which seems ridiculous to me.
We can temporarily disable Start&Stop which we'll have to do whenever we anticipate a hill start.
In principal SS was good idea but in practice it's temperamental and fiddly and due to the particular way the car must be operated for it to work correctly in my book it's dangerous (not for everyday use but steep hill starts or anywhere you need a strong bite to safely pull away) . I thought we were supposed to drive the car not the other way around.
Just remember though that he's stated above that he's keeping the clutch depressed for 10 seconds plus.....u def dont need to use the handbrake to use the SS system....that IS rubbish youve been told...
i simply- pull up to a halt, take out of gear, release clutch...engine stops.....depress clutch, put into gear, engine starts...THAT simple...how you choose to keep the car still is up to you- as the system has no connection to your brakes- i presume just a speed sensor...it will even work if you use it on the flat with no brakes applied after stopping.
