Styling brembo brakes
bravohgtlad
irvine
just bought a set of brembo calipers was wondering do a have 2 buy different discs and would the coupe turbo 1s fit my hgt?
Your going to need custom mounts to fit those callipers to your HGT. Its nots so straight forward and will cost you abit to get it done.
Furryballs has done it ill send him a PM
You will need 16" wheels to take the calipers not sure on ET/offset side of things though might need a lot of width aswell.
Im quite sure he just changed the hubs and track rob ends from coupe to HGT though.
alright there, all i used were hubs, disc's, disc's are 305mm so you will have to use them off the coupe as the bravo's are a 284mm (i believe), calipers, pads and track rod ends or tie rod ends if you will, hubs go straight on, you'll have to make some new brake lines. now the abs sensors have a different connector so leave the bravo one connected and cut it at the hub, and cut the one off the brembo at the connector and solder them together make sure its a v.good join or the abs wont work and your light on the dash will stay on.
Do you know if i can use brembo calibers with 284 diameter disks, hubs from coupe, and 15inch wheels with 32 offset.
Are the hubs from coupe versions all the same, or the 20VT has different ones..?
The bolts patterns are 4X100 am i right...?
i doubt very much u can. reason being the disc will be completely different and the pad wont make proper contact with the disc. and also the coupe brembos only fit 16" wheels or bigger
and the wheels are still 4x98
weird thought but i 'll say it.
can the wheel bearing of barchetta fit inside the hub of coupe....?
if it is possible the bolt pattern stays the same.
Are the Bravo set up the same as the Stilo does any body know. I really wanna fit brembo's to my Stilo. This is after i have just spent £100 on spraying the OE calipers lol.
