ladywallace
Looking to upgrade discs... what would you recomend for a like for like swap upgrade and where is best to buy them??
Thanks for looking
Thanks for looking
Ive got 16" wheels on mine does that make any difference?
Brakes aren't like wine - they don't improve with age. Most times people upgrade brakes or shocks or bushes they report amazing improvements over the stock set up but most if not all of the improvement was due to the old stuff being knackered in the first place.
I've seen a brake fluid change produce a 10% improvement on a rolling road. The rubber hoses get soft with age, increasing the response time. Internal seals wear, caliper sliders don't slide so well and pistons get lazy. All of these are generally neglected and degradation creeps up on you slowly until the day someone driving a newer car climbs in. Fair dues to hubby, he clearly values your neck. Someone worried about your brakes is not to be taken lightly.
Ultimately whether you change the stock set up or renew the old the tyres are the ultimate decider of stopping distance on the road. The benefits of larger discs really only come into their own on the track and are more to do with heat dissipation and fade resistance when your foot is hard on the brake pedal more than half the time.
Renewing the stock set up you can rest assured that everything will fit whereas going for an upgrade can be more of an adventure as things may not fit and you end up having to get more bits than you bargained for. Bigger discs look cool as well![]()
