General  Bravo two months later
Spotstilo
I've had my Bravo 120tjet for over two months now, and I do like it. Generally it's been great, everything works, and it's lovely to drive; looks nice too (y)
Few things to report:
1. Noticed today (very hot) that the air con was noisy; lots of vibration when fan turned up, doesn't seem as cold as it should, and (this might sound weird) , but the car seemed sluggish taking off in low gears when the air con was on, then seemed OK when AC was turned off:confused:
3. There is some rattle from the belts when idling, it had the cam belt (kit) done just before I got it.
4. Seems a little too bumpy; can even feel the dimples in the tarmac at very low speed: is this right? My Stilo (the only other Fiat I can compare it to) wasn't this bumpy.
Any ideas on the above before I take it in to be looked at?
Thanks.
Hi there i have same problem with my aircon ,very noisy and very sluggish in low gears but still ice cold
My AirCon makes the car noisy, it's the fan behind the radiator making most of the noise, and the car will be sluggish with it on, it's only a 1.4 and Air cons draw a fair amount of power, when the turbo kicks in though it should be barely noticeable
Though I reckon you may need your air con regassed as when mine is on, it freezes my eyeballs,
Thanks for the input.
I'm getting it looked at tomorrow, hopefully just needs re-gassing :)
Cheers.
