General  Bravo gear selector cable
AndyLeon
Swansea
Hi all
I’ve got a Fiat Bravo 1.4 T Jet 2009 plate. It needs a gear selector cable but apparently they don’t make them for this model. Has anyone had any joy sourcing them or an alternative.
Andy
Model
Bravo T Jet 1.4
Year
2009
Hi all
Andy
Anything like this on eBay?eBay item number:354205054826
Hi, unfortunately I don’t think that would work. I’ve managed to get a photo of the original and it looks different. Thanks though
Maybe try putting your car's exact details or Reg. No. into www.autodoc.co.uk . This parts supplier lists several brands of gear selector cables for the 1.4 T-Jet. It seems there are 2 different length cables needed for your car.
Hth.
Hi, Use fiat ePer with your vin to find them. For my 2009 1.4 Tjet 120hp codes are
MAXGEAR 32-1222 and MAXGEAR 32-1221.​
OEN 55228581 and 55228582
I live in Italy and you can find them on ebay fiat Original but they are like 50 and 90 euros depending on which you need, or there are 2-3 companies that make them aftermarket.
Does it need a cable because it's broken or because the shifter is hard to move left-right ? If it's the second, it might be the pin of the gearbox mechanism on the m32 gearbox that is too tight or is not greased, the one that moves the mechanism up-down (left-right inside the car).
Edit: I looked at your picture and that looks like the cable that goes front-back inside the car so it's not the pin problem.
The one you have in the picture is OEN 55228581 and looks like this
Is it maybe the bush in the middle of the circular part thats worn out? If it is you can use a mk1 golf gear selector linkage kit to replace it . I did on my previous tjet and it worked perfectly
