Technical Bravo t-get throttle body relearn
electric73
Hello, is there any way to make a reset/relearn on the throttle body? I have a suspicion that in particular driving conditions ECU doesn't know the air volume in the throttle and indicates an error. So first want to reset it if possible. Couldn't find an option in AlfaObd. Any recommendations for another software - maybe Multiecuscan? I found this for Fiat Stillo, can I use it? And should remove throttle connector or not :rolleyes:
1) switch ignition on (DONT START) for one minute
2) switch ignition off one minute
3) start car (DONT TOUCH THROTTLE AT ALL) and let idle until cooling fan cuts in (10-15mins)
4) switch off
5) repeat step 1
6) repeat step 2
