This guide is intended for cars using 257mm 12mm solid discs and drums. Set some time for the conversions and safety safety safety!
I also recommend a handbrake upgrade, this one to be precise
New discs, pads, pipe (rear discs) and fluid is a must (dot 4)
You will need:
You will need:
- Impact socket set (half inch drive)
- Trolley jacks
- Professional bits set (allen/ torx bits etc)
- Ratchet socket set (3/8 and half inch sets)
- Various spanners + Screwdrivers + hammer + vice grips (4r and 10r)
- 3/4 ratchet and 30mm socket (rear disc conversion)
- Syphon (rear discs)
- Plus gas (for stubborn bolts and nuts)
- Flaring kit + cutter + pipe (rear discs)
- Bleeding kit
- Paint (optional)
- Time
