I don't see the difference in starting with the hgt. If you've got a complete coupe donor your going to be using everything from it, ie the complete front subframe, rack, pipe work, struts, hubs, brakes everything.
And the same at the rear. Using the coupe complete rear axle.
I believe hgt's should be kept as hgt's where as Boggo spec models are cheap and plentiful.
