Technical Bravo AC at minimum on start up
tishka383
Hi guys,
I have so many questions :D so he is another:
When I start my Bravo 1.4 Sport 12 plate from cold, the AC seems to be at minimum setting (Not what I had it at before). Once the engine temperature starts to rise the AC comes back to the set setting (what I had it at before).
Is this normal behaviour?
Sounds normal to me. The system only jumps into life once the engine is warm, then itwill work hard to get the cabin temperature up to the correct level. My mrs used to fiddle with the controls until told to wait for it to warm up.
It can only do its work once there is heat available to deploy. This prevents it blowing cold air into the cabin which is not really what you want on a cold morning.
