Technical Bravo 2008 1.9 mjet Airbag light no errors
Omas
Hi all, I hope someone could help me with my problem. I replaced battery, checked earthing grounds and fuses and done proxi alignment, but airbag light and message is still on. No errors to be find, only one stored B1002 low battery erased and never came back. I own a car 2 months and don't know it's history. Also no seat belt light or buzzer and no belt buzzer volume in menu. Is it faulty airbag ecu or do you have any other ideas?
I have exact same issue. Mine came up on the highway, no code, just error on the dash.
The only thing I noticed is that while passenger seat belt light and beeping is on, driver is stuck in "fastened" and 0mAh. I am sure I was getting the beep before. Could it be related to that? Can you check values for your seat belts? All resistances of all airbags seem to be ok, no other issues.
Hold on, I looked at your screenshots, how come all airbags resistances are 0? It should not be the case...
That's why I think there is a problem with airbag ecu. When using multiecuscan I can't even turn on no seat belt light from airbag module actuator.
Most probably airbag ECU is fried. Strange that you can even connect to it. Have you tried proxy alignment? What does it say?
Also, check body and instrument panel modules, any errors there?
Airbag ecu replaced today and all is working again. I had to do proxy alignment as mileage was blinking. Airbag ecu costed me £62.40 including delivery.
Great! May I know where you got the ECU so cheap? Mine is also fried as it appears...
