General Brava Abs Pump And Modulator Query
LouC
My 1997 Brava has just failed its MOT as the ABS light is constantly on. The diagnostic test told me that the Rear RH speed sensor in OC was causing an intermittent fault and the Front left load valve is causing a constant fault. I have managed to locate another ABS pump and modulator but the part number differs to the one in my car. Does anyone know if they are interchangeable? Many thanks.
not sure, i imagine there will be compatibiltiy problems between the 1.8 and 2.0, but i dont think age will matter, so if your parts are from a car with the same size engine i would be fairly confident they can fit.
