Technical  Brakelight sensor problem
Stephen Mark
Herne NRW
Hi everyone, ive replaced the main brake cylinder and wanted to use the sensor, that snapped off so I ordered a new one.
The pins broke off the new one ....
I've soldered it and it works.
The sensor however will not screw fully in and is super tight, I wont over do it because I'm sure this will snap too.
Any ideas?
Model
Fiat 500L
Year
1971
Mileage
50000
Any ideas?
Sounds like the wrong sensor, you will damage the cylinder and if it screws into the master cylinder then a good chance it will leak and be dangerous.
Most things you should be able to screw in with your fingers nearly all the way and just finish off with a spanner etc.:(
