Technical Brake upgrades
Parko
ARMAGEDDON!!!!!!!
W.Yorks
Hi Guys
Can I just strap some coupe 20v discs and brakes on my sedici or is it a little more complicated than that?
Seen some coupe 20v brembo calipers and thought why not give the beast a proper upgrade.
Thanks for your time
Parko
Hi Guys
Parko
if you fancy a long read into brake upgrades click here
think it needs mounting plates to fit the larger callipers. which would have to be found/machined.
then you also need the alloys to fit over the larger brakes, if the existing ones haven't got the clearence needed.
to fit brakes from coupe 16vt or 20v is best change whole struts and driveshafts aswell...
No its not, 16vt calipers go straight on with sedici discs is easy as that.
20vt brembos have wider spacing, needing either adaption or 20vt struts hubs, wish bones, steering rack (coupe 16v) and wheels to clear the calipers. That lot doesnt actually cost so much as for breaking the struts and hubs etc are worth very little. the track is wider hence the rack as the tipo one will not reach the hubs.
I have coupe 16v rack 20vt wish bones (all the same on the coupe), tipo hubs, 16vt calipers on brembo tipo discs, I could out break all the coupes at mallory with ease (although the tipo did weigh less).
rich
rich
sorry, i thought that 16vt have brembo calipers.... which are fare bigger... i tried to fit 16vt coupe driveshafts into my tipo 16v and find different hubs /conus on cv joint different/
I tried to hit eper last night and just got confused over which brakes the Tipo came with.
The coupe 16vt seems to have come with a choice of 4... two of the 15mm pin and 13m bolt type, and two of the 7mm hex pin type.
I've a set of the hex pin type from a Marea weekend 2.4TD (same as 20v) - are they smaller piston than the 16VT coupe ones?
I'd have put links and images but the eper is broken/busy as usual.
I'll whip out the calipers then, and a set of calipers and get the pistons measured.
Apart from anything they seem a better design as the 15mm pin seems to jam up with heat and brake dust, and it's inside the caliper and unservicable. Nobody seems to want to buy them so rather use them myself than scrap them.
If the pistons move then they'll be ok, I just painted mine checked the pistons moved and the caliper would slide then stuck them on and bled them - job done.
