Technical Brake Fluid and Coolant
Adam1984
Merseyside
So looking at this brake fluid in my 1.2 Panda Pop Petrol, does it look like it needs changing as I have no record of when it was last done.
If it needs doing will do coolant at same time and transmission oil.
What brands or each:
Brake Fluid
Coolant
Transmission Oil
Would you recommend to get?
Model
Panda Pop 1.2
Year
2015
Mileage
61900
Brake Fluid
Brake fluid deteriorates with use, should be flushed/bled 2-3 year intervals tops.
It's hygroscopic (it absorbs moisture from exposure from air), and deteriorates from constant heating at the brake cylinders/calipers.
That's why you don't leave the reservoir lid off or loose, or use already opened tins that have sat about after being opened and you have lying around..
A good branded DOT 4 fluid.
I heard Castrol do one which burns at a higher temperature called React. Does it make much difference?
You're not setting fire to it :unsure: :LOL:
Higher boiling point is a good spec to look for , but marketing speak often just comes out without the actual spec.
Look for the actual detail and compare.
I don't do brand recommendations have a look in the handbook I think DOT 4 is the spec. If you don't have a handbook with the car there is a downloadable version. Coolant just use the same colour (pink or blue - I don't know which).
