Technical Brake compensator valve ???
Sevenoaks Kent
Hi guys
In the process of removing the rear subframe for refurbishment
Also wanted to return the compensator valve
But where the mounting bracket is there is no valve
Is there any other place on the rear where it might be
As I thought they were fitted to all cars
It's fitted to my 147 20v
ABS on rear disks: Electric brake balance by the ABS unit.
It basically opens and blocks the line to the rear to regulate the pressure in there instead of the mechanical valve with spring load.
