- Joined
- May 15, 2011
- Messages
- 3,769
- Points
- 588
I've noticed that in the handbook it says to change the bolts and spacesaver if you change from steel to alloys or vice versa.
Searching through the forum it seems like the bolts are the same and I'm guessing the spare should be fine as the circumference of the 2 wheels is very similar.
Is that right?
Another member on here was concerned about using the lock nut bolt on the space saver. I understand that in the UK you get wheel locks on the non-POP models so you only have 3 'original' bolts for the space saver. Not to sure if it's referring to this
So if you have sourced new alloys don't forget to get lock nuts for them.
