Technical  Blue & Me module missing
kingfox10
Somerset
Hi All,
I have just bought a 2013 plate Panda twin air 4X4 with a flashing odometer.
Investigations have revealed that the Blue & Me unit is missing.
As I do not know the part number, can I fit a secondhand unit from another same model Panda?
There are some available on Ebay but will they work?
Thanks for your help in advance.
Regards.
Model
Panda twin air 4x4
Year
2013
My understanding is they are not car specific so should work. The B&M is a fragile thing it seems so be careful as you may buy a broken one. There is a firm mentioned on here that repairs them for a reasonable-ish sum (Bradford based)
You will need to do proxi alignment (system reboot) once a B&M is fitted. This will stop the flashing milometer. This requires MES software. See MES register on here for peope near you who may be able to help. Do use the search facility as there is quite a lot of info here already. See both Panda and 500 forums for a good spread of results.
Hi All,
Regards.
Here's one that broke earlier... From my 2013 TA 4x4
It was eventually replaced with a secondhand one from an Alfa (Mito I think) which was a different shape so didn't fit the underseat bracket properly but was "plug and play" (no programming replied). Repaired units appear to require their "address" being reset or identified to the CanBus. My full experience is described on here somewhere.
