Styling Blue Lights
Styling Blue Lights
No pic... but... If you look at the fuse box under the dash, you will see the main set of fuses all together. If you look to the left hand side of them, set back a bit is a 7.5A brown fuse sitting on its own. That's the one you need.
I fitted the bulb. It looks really cool in red, but it can still just be seen when i took the dim/dip fuse out from the far left (just back) 7.5A. Should it completelty turn it off as it only turns off the headlight bulb when it is on dipped. Is there any way of doing it so that it cant be seen at all when h/l's are on?
