Technical  Bleeding Clutch Question
AyLa
Newcastle
Hello,
So after searching this forum, I've read that you can bleed the Clutch via the Slave Cylinder by:
1) Removing the rubber cap on the nipple which sits on top of the Slave Cylinder
2) Releasing the metal clip on the Slave Cylinder
3) Pulling back on the pipe which goes into the slave cylinder by about <10mm
Would air not be drawn in to the slave cylinder once the pipe has been pulled back ( gap between pipe and slave cylinder ) ? or possibly air drawn in via the bleed nipple given it's on top of the slave cylinder ( i.e. lack of gravity drawing the fluid out ).
Thanks.
