- Joined
- May 26, 2011
- Messages
- 232
- Points
- 161
2006 Doblo Multijet, Discs front, drums rear, ABS.
Well overdue for brake fluid replacement.
Good news is that there was only a bit of discoloured/contaminated fluid that needed to be bled out (front discs).
The not so good bit is that I've somehow managed to do something leaving the pedal feeling a bit spongy.
Here's what I did: First of all tried an old brake bleeding kit, which is a replacement reservoir cap connected up to a pressure vessel (with pressure gauge), the cap wasn't a good fit it leaked air and for some reason the level in the reservoir went up when pressure (10psi) was applied (did I put some air into the system by accident at this point?). Gave up on that and did the rest of the job with the pump and hold method.
I know I must have introduced some air to cause the sponginess, my question is how to get it out? Should I just keep on bleeding until the air finally works it way through the system? "Pump & hold" method or should I get hold of a more up to date bleeding kit with integral fluid reservoir (Gunson Eazibleed type).
Any suggestions much appreciated.
Cheers
Ron
Cheers
Ron
