Bit of an obscure one!...Q. Which fiats have a square seat belt release clip
N
nico
Bit of a shot in the dark i guess on this one,
but just wondered if any of you knew if any of the other cars have a squareish receptor and release clip, rather than our bravos round / ovelish ones?? (anyone got a parts CD they could perhaps look this up on for me??)
could try here its workin
http://www.findmyoldcar.com:7080/navi?COUNTRY=012&SBMK=C&DRIVE=S&MAKE=F&PRINT_MODE=0&LANGUAGE=3&WINDOW_ID=1&SB_CODE=-1&ALL_LIST_PART=0&PREVIOUS_KEY=tlHome&KEY=HOME&ALL_FIG=0&GUI_LANG=3&EPER_CAT=SP
Pete
BravO 1.8 GT (Import)
T reg 1999
Abarth Kit, Leather, Power Flow Cat back,
Sparco Strut Brace, JBL Sub, Crap amp!
Marea Console in Progres :) Gettin there
Dash Spraying in Progress :) Centers done!
Cheers Pete
Not havin much luck with the search.
Useful site though.
the sites not always up, thats the only problem with it,
could try asking on the fiat forum,
Pete
T reg 1999
punto mk1 and i think mk2 seatbelts should work in a bravo. the only exception is the centre belt receptacle. its designed so that the side belts wont plug in, so you need t take both parts of the middle belt. Not sure about the fronts, but i'm pretty sure they'll fit. The bolt that goes into the floor is the same, and takes about 300 turns to get it all the way in! they are flippin long!
Buzz (formerly LightWarrior)
The champion of the Bravo 1.4
Owner of the Bravo 1.8
http://www.bravo-guide.co.uk/members/59ianalexandria.htm
Thanks guys.
Its just the fronts I want to replace, but I need the plastic housing to be something like a rectangle, and I'm led to believe they are that shape on some fiats, else I'll search for some of different manufacturer so long as clip will still clip in (are they all generic dyu know?)
The Alfa will fit (most i think)
I have the Alfa 156 front seats and the bit the belt clips into is built onto the seat and the Fiat belts still clip in so i know you could use them.
Mine are the standard ones on the Bravo/a just the Alfa clip lock
So whatever the standard shape for the Fiat is it's the same for the Alfa
S
1
792
Dark Lurker
1
655
Dark Lurker
1
7K
Dark Lurker
