Tuning Bike carbs
Tuning Bike carbs
tomo3292
RIGHT THEN!
how easy would it be to add a set of bike carbs to a 1108 sei fire engine, ive heard good things about this, and havent seen many done so thought i'd see if anyone has experience or completed it themselves.
cheers
Here is an example of a 1108 running with dellorto DHLA 40 delarue
-http://www.youtube.com/watch?v=_6v7ZvaRk7Y
-http://www.youtube.com/watch?v=uBZJUoIVTFE
Wich is the car of this treaad:
-https://www.fiatforum.com/cinquecento-seicento/287284-delarues-1108cc-wolf-sheeps-clothing.html
Unfortunatly this cinq isn't on the road at the moment and has not done a dyno run. However there is an other cinq on wich this exact same set was first mounted. This one did do a dyno run with an outcome of about 80hp.
The DHLA 40 wasn't the only modification offcourse ;)
To be honest I haven't got a clue. But I am guessing not, since it was also decatted....
So it pretty much had to be an miracle if something like that would ever get through emission testing
More than a miracle, it would just be plain bent...! :)
There were cases many years ago where dumping the very poor injection system and fitting a pair of twin-choke carbs instantly got respectably more power (ie Astra GTE 16v with the red-top engine). But that was pre-Cat. Injection systems have also moved on a lot since then.
