Summaary of this thread as its got a bit mixed up.
@Adam1984's (the OP, or Original Poster) car does not have stop/start (it's a 1.2 Pop that didn't offer that)
However, the OP posted a photo back at the beginning (in march this year!) of the battery in it at that time, which was an EFB (stop-start) battery - which is
not correct for this car.
The correct battery is one that is labelled 12 volts, roughly 50 A/hr and around 360A cranking , but
not marked AGM, EFB or 'stop start'. This correct battery is often labelled Type 012 or 079
Any make of battery will be 'good enough' - Varta, Exide, Lion, Halfords... Any of the ones on this link below are correct (and this is a very good mail order battery company with cheap, next day delivery)
https://www.tayna.co.uk/vrm/YO15WPD/battery -- the primary difference between them all is how long they are guaranteed for: longer = more expensive.
For a 'simple' car like the Panda, the A/hr rating (basically how long it can provide power with the engine turned off) only needs to be 35-50A/hr... more is not a problem, but not needed. The other number, eg 360CCA, means 'cold cranking amps' -- how much current it can supply to the starter motor on a cold day. A bigger number means it can start a bigger engine. The Panda only needs 360 or so... a diesel Panda (or a bigger engine on other cars) needs a higher CCA rating as they need more power to get the engine moving.
The battery can be taken out and put back without needing any codes resetting, and so you don't need a memory saver
Talk of a braided earth strap. The is NOT connected to the battery. The battery earth connection (or negative wire - same thing) is a thick wire, as seen in the photo in the earliest post. One end is connected to the battery and the other end is bolted to the metalwork of the car on the inner front wing. All circuits in the car have a positive wire connected to them, and the negative is connected to the metal body at a convenient place (for example, the negative wires from the back lights are bolted to the car body inside the boot). This saves weight and cost by not needing to run a negative wire all the way back to the battery from each item, because it uses the metalwork of the car as a connection instead.
The braided earth strap is only used (mostly) by the starter motor, to connect it to the car bodywork. This is flexible (braided) because the engine can move slightly on the rubber engine mounts which might break a solid wire.
