Technical  Battery ?
Technical  Battery ?
Wilby , Northamptonshire
Hello peeps ,
I have found an intermittent electrical fault with my Marea .:bang:
Sometimes when I start her up , it almost seems to die as it's turning over , then will kick into life as if no problem .:confused:
Could this be a faulty battery , alternator or something else ?
Any comments and help would be gratefully accepted .:worship:
Regards Jason :cool:
When was the battery last replaced? Mines used to do this on the coupe and although the battery was only 2 years old, it had been left uncharged for 6 months and ended up not holding a charge or doing as described above.
Ross
best to get a voltage tester on the battery to see if its holding charge, it does sound like the battery is duff but need to confirm.
check the voltage with the engine off and it should be something around 12v, start the engine and it should increase to around 14v as the alternator is charging. should be obvious what is at fault from there
Varta Battery
50AH
250A
If that makes any sense to you Ry .
Jay :cool:
50 Ah = 50 A /hour or 1 A / 50 hours. Get it? It is the eaqual of the charge of the battery.
250 A = value of the electrical current, if you would shortcut the battery
