Just fitted my 096, took me about 10mins.
For those wanting to know how to do it:
1) remove the battery cover (its got torx headed bolts, but you can use a 5mm allen key on them)
2) remove the battery clamp, two 10mm bolts at the front and the rear - you'll need a socket with an extension for this
3) disconnect the earth with a 10mm spanner - dont need to take the bolt all the way out, just loosen
4) as soon as its disconnected, either put some tape over the earth, or put the cap on from your new battery
5) unscrew the two phillips screws which hold down all the connectors near the +ve terminal
6) disconnect the +ve terminal as per (3)
7) again put some tape over the terminal
8) Pull the old battery out and replace
9) reconnect the +ve terminal
10) screw in the top plate
11) connect the earth
12) fit the clamp - make sure you dont drop the bolts!
13) start the engine, make sure everythings ok, no loose connections etc
14) refit the battery cover
Job done!
