Hi, my sons punto keeps draining out the battery, its a new battery and its been checked, also i had the alternator checked which is fine,
I've checked the drain with a multimeter which shows 0.06 and this is from the radio, i know this because i checked the fuses to see,
the only thing that shows a drain is when i turn on the ignition then turn it off, you can hear the relay clicking on but not off, it shows a drain of 0.77 until the relay clicks off, which takes several minutes,
do you think this is the cause of the draining battery? the relay (which is off the car at the moment) is white and has the name of BITRON on it, also NORS 240113.
All help will be really appreciated, Thanks
