Didn't have any fuel issues before. This all started when I rebuilt the starter, which now works like a champ.
Guess I need to check the points and condenser now. Any tips?
Assuming you do still have points and condensor fitted not after market electronic ignition.
Is it just possible the ignition was left on whilst working or testing starter for more than a short while?
Reason I mention it is it can cause coil, condensor, points or all to overheat and fail.
First have a close look at the points, ideally the contact area should be smooth and clean with no pitting etc.
If when looking at the contact area they are what is described as "blue and pitted" surface that generally means the condensor want's changing along with the points.
The job of the condensor is to prevent "arcing" at the points (basically excessive sparking) which soon knackers the points and will give a persistant misfire.
So once you have a new or good and clean set of points, I always put a tiny bit of high melting point grease on the heel of the cam contact area on the fibre or plastic that rests on the cam lobes opening and shutting the points, the reason for this and a lot of people neglect it, is it prevents early wear of the fibre heel which closes the points gap and causes premature failure. Make sure no grease gets on the point contacts.
Now with the correctly fitted contact points turn the engine pulley until the points are at their widest position open and set it to 15 thousands of an inch gap. Someone will say a "correct " clearance but that is a good starting point and will not be far out.
If you want you can lay the spark plugs connected to their leads on the metal of the engine and get someone to spin it over and you can visually check for a good "blue spark" jumping the plug gaps. Then reassemble and start engine, if all good you may want to check timing using a strobe timing light.
Sorry if over detailed explanation, I first started doing it as an apprentice in 1969
