this is on a jtdm 16v 150 with a smf conversion, uprated sprung center organic disc, uprated plate, been on car for nearly 30,000 miles good couple of years now (had similar issueover a year or so ago but did clear up, only did it for a day or 2 and nowhere near as bad only once per trip maybe, put it down to dust on disc?.)
just had my car up on ramps for a few days while i redid some intercooler hard pipes,anyway came to test yesterday and on taking up drive to back off ramps juddering a bit, to get out of my drive i have to reverse uphill and turn and the judder was really bad shaking the front end no matter how much i tried to slip the clutch at the bite point it judderd.
got out of drive eventually and onto road flat and straight, came to pull off in 1st bad judder again, hoping it was dust on plate from getting onto ramp i took it for a spin.
on the move no issue at all, no crunching gearchanges no judder when letting out in next gear, no clutch slip.
at moment im back on drive unwilling to take out on road again.
ive searched all judder related posts and looked at the rear engine mounts (x2 for me)accessable from side of car with a power bar and slackened off(were tight)a few turns and then retightned tight.
im a largish fella and gripping engine from above im unable to rock engine in any position.
open to any suggestions for other things to check.
just putting a video up on you tube off camera up on bonnet as i cant see engine movement from drivers seat, but not much movement seen compared to fixed items in engine bay etc.
http://youtu.be/BkEllaBwq7c
many thanks
many thanks
