I have an 2003 Arto 69GL Automatic.
She was UK supplied when new (Marquis Motorhomes) and ordered as LHD for continental touring by first owner.
Automatic Gearbox has decided to go into LIMP HOME mode. The first problem was the inability to move the gear lever from Park. Using the mechanical by-pass I can get the gears although only in 3rd gear as limp home mode in activated.
I am a retired Auto Electrician so thought I would look at the Solenoid release for the Gear Lever having ruled out the brake switch. When I removed the cover around the gear lever I found a 7 way connector loosely lying in the area and a PC board which amongst other functions drives the solenoid BUT with no wiring to it. It seems as though the 7 pin connector has broken free and I am unable to re-connect it.
I have tried unsucessfuly to get a wiring diagram for the base vehicle Ducato 2.8gtd. Tried my local Fiat dealer who could not help and wondered if anyone is able to supply a wiring diagram as with that I will be able to hard wire the PC Board which is most probably the reason for the ECU taking its action.
Any help most welcome, thanks
Dave
