Technical  Auto scanner
I have an Epson V200 flat bed. Also does slides/negatives.
It's fine for reasonable scans of slides but our pre-digital cameras were not great. VERY slow on higher resolutions but most are.
Don't get me started on printers..........
Michael - unusually I wasn't being sarcastic with the scanner advice, I assumed you meant an image scanner.
Are you talking about a FIAT device to plug into to read error codes and the like? A few folks on here I think have various devices.
You all were right! I didn't make it clear on the first place... Never mind.
I am looking for a device like the one cammy89 suggested. Searching on the ebay, I found this
http://www.ebay.com/itm/Actron-auto...616&pid=100033&prg=1011&rk=4&sd=130612870826&
and I honestly do not know if it's money worth spent or not!
Do you guys know, if there is a significant difference between the two? Is there something that the second one is capable of and the first isn't ?
Thanks for the advice.
http://www.ebay.com/itm/Actron-autoscanner-Cp9580-Plus-obd2-ABS-code-scanner-/251116444459?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D3775703726151162616%26pid%3D100033%26prg%3D1011%26rk%3D4%26sd%3D130612870826%26
what are u actaully looking for it to do if its just to diagnose a fault or reset an engine managment light first one will be fine if you are wanting it to do much more than that then second one seems a better choice?
I do have a laptop. What kind of software shall I use. And where can I find the cable with USB on the other end?
