Technical Android Auto - Fiat Panda Mamy 2009
Vidhya
UK
Dear all,
I am planning to install Android Auto in my Fiat Panda Mamy 2009 Model.
I searched around on a ecom site, and they often refer to a 2DIN - is this something compatible with the 2009 model?
If not, should I look for a 1DIN?
Thanks.
there is space for a 2 din you just need to find a 2 din bezel, i have a alpine halo 9 in my 169 from 2009, it is a 1 din radio but if you want one that does not stick out and is a bit cheaper you can for sure find a 2din bezel and a radio that fits that...
The forum has an I.C.E. SECTION (
in car entertainment)
there's plenty of advice on which 2din bezels fit
the power to the OEM radio is controlled via Cambus. You will have to add a can bus widget thing or patch in a ignition switched wire to control at via the key.
