ARRRGH!! Dreaded leak is back
J
jez
As title.
Couple of months ago was getting a leak in passenger footwell. Decided it was sunroof leaking but couldnt get a garage to touch it!!
In the end decided to just seal the sunroof with sealant. However, this last week the puddle is back in the footwell again.
Does it just need resealing do you think?
Cheers in advance for any advice
Could it be the underscreen drainage channel holes that are blocked? Leaves etc.
Mark.
Council estate lad.
And proud of it!
Member of the Guild of Experienced Motorists.
leak
You mean the ones under the bonnet? No checked there all clear. Maybe I need to just get stronger/better sealant!
The joys of the bravo :)
Hello, i have a 1.2 80sx 2000 reg bravo which had the exact same problem except i dont have a sunroof. It took a while to find out but eventually i have solved it. Firstly check the passenger door. I know it sounds obvious to make sure the door is closed properly but when i stood at he front of my car and looked, i noticed the top of the door stuck out slightly. Took it a garage, he pushed it back in nd bingo, all done. BUT being a Fiat the proble came back with a vengence!! Was told it could be the matrix heater leaking, had it checked and there was no problem, so i went to a shop and bought 2 packets of radiator cement, put them both in and have never had the water back (touch wood!!)
J
1
1K
Frank
F
K
2
1K
Dark Lurker
M
2
160
M
S
1
7K
Streak2013
S
