Technical Anti roll & driveshaft questions
Rock Kicker
Evenin'..
In the middle of some work on the old man's 92 Tipo 1.4 and I've run into a couple of problems.
1. The inboard driveshaft boots were totally shot, so he ordered some replacements from a local supplier (not Fiat). Pulled the driveshafts out no problem and pulled the boots and bearings off. However, new boots that come with bearings pre-fit only fit the right hand shaft. The left hand shaft appears to be slimmer; the bearing that fits the right hand shaft will slide all the way down the left hand shaft to the CV - is this correct? Do I have the wrong part or a dodgy driveshaft?
2. The anti roll link bush was shot to bits where it engages with the anti roll bar, giving the damn annoying clunk over every little bump. Ordered a new link from Fiat as the bush is an integral part of the new one. Removed the old one same time as the driveshaft, but it appears to have left behind a part on the anti roll bar, which don't seem to want to come off. Now I'm hoping that it's not part of the bar and is just being stubborn as the new link won't go on with it there. Hard to describe, so I shoved the mobile in there and took a pic - apologies for the quality, but it was raining, dusk and the camera's useless :)
that part on the roll bar is the inner sleeve and the rubber. It is just being stubborn, you might need to use an angle grinder to thin the sleeve until it cracks and comes off the stud underneath.
Please photo the driveshaft issue.
rich
Thanks for that - I was thinking of resorting to the angle grinder after the bearing puller failed to remove it.
Photo'ing the driveshaft could be tricky - the difference between the two wouldn't show up, but I could probably measure the diameter of them. It's fair to say that's there's probably 3-4mm difference in diameter between the left and right hand shafts where the bearings sit. I'm not sure if the difference is only at this point, or whether it extends all the way from the tripode joint to the CV.
Update - I had a chat with a local Fiat specialist after the Fiat dealership offered next to no useful information; he seemed to think it quite bizarre that the boots were supplied with the bearings fitted into them. Long story short - the left and right bearings are different sizes; 22.9mm diameter for the left-hand shaft, which I've now got.
