Another chopper ditching
Stuart
Prominent member
yesterday, thankfully everyone got out ok, conflicting stories about what had happened tho but I see the news are reporting 'fuel contamination from the rig'
EDIT: now heard that someone on the chopper mentioned a gearbox issue, going to have to wait n see with this one.
Wasnt a Bond this time Andi, it was a CHC Scotia chopper
different company, but crucially SAME helicopters....
Id heard ALL companies had grounded their choppers, but saw one overhead today...
Probably a different type of craft.
I'm guessing some were flying today as it wasn't commented on at work and we always notice when they're halted. I know that sounds backwards but we're right next to the airport and it gets to the point where incoming flights and helicopters are just background noise.
The silence when volcanic ash halted everything was very eerie :D
Anyways, beeb are reporting this ditching was due to a failure in the lubrication system (naturally I have no idea what that is) and that a more serious incident was narrowly averted. I'm glad no-one was hurt however this will probably lead to all Super Puma's being grounded which is going to cause serious problems to the industry. Still, better some chaos now than devastation later
Hope you get home soon Stuart but
I'll try & make this sound simple for you Katie.
The Lubrication system is like the oil in your engine, if it fails, bang goes your engine.
In a car it's expencive enough, in a Helicopter it's bloody expencive.
As for Helicopters, I've grown used to the sound of a Sea King Helicopter buzzing around, as I'm only 4 miles from RNAS (Royal Navy Air Support) Prestwick, sosee & hear rescue 177 flying over the house pretty much every day.
Well that's a great sodding start to the morning - getting patronised by Andi :rollseyes:
Mind you, I did ask for it by assuming something capable of hovering and flying might just be more complex than a car.
I'm shocked to discover they're more expensive to fix though ;)
nah, although it was a super puma, it was a different model to what was prone to going down before although Im sure they would have common parts.
Scotia and Bristows cancelled flights with that type of choper, Bond only showing delays
Heard that it wasnt a lubrication issue, noise was heard by the passengers and the pilots decided it was best to ditch. Apon inspection of the gearbox, a 360 degree crack was found on one of the gears on the shaft that drives the rotors. Great decision by the pilots to ditch IMHO.
And a seized gearbox on a chopper would be a lot more than expensive, its fatal!
AAAAANNNNYYYYHOOOOOOOO
Might be getting off by boat on monday which will be fun, google 'billy pew' and see how its done lol
Report here http://www.aaib.gov.uk/cms_resources.cfm?file=/S6-2012 G-CHCN.pdf
Good luck getting home by boat - I've heard some great stories about that :D
yeah heard something about that and had to laugh, i mean, if it breaks over land, will it be any safer? lol
was thinking more along the lines of:
if a chopper breaks down at normal flying height over water, 100% chance of death
If a chopper breaks down at normal flying height over land, 100% chance of death.
Its not the fall that'll kill, its the sudden stop at the bottom
