Technical  Annoying beeping after start
Romin
I bought Fiorino 2008, 1,4i. All is ok except annoying beeping which starts as soon as car start moving. The beeping is very long (cca 2 min.).
Car was quiet until i found and set in menu some Setup feature like Seat belt buzzer: On and other two things. After that car begun beeping.
I cannot remember what i set but when i look to menu again - the Setup option is missing (before was there).
No info lights are lightning, only crazy sound.
Any idea?
Thank you.
Car was quiet until i found and set in menu some Setup feature like Passenger belt alarm: On and other two things. After that car begun beeping.
Any idea?
Thank you.
Sounds like the passenger seatbelt reminder. Possible the switch in
the seat is broken. Try clipping in the seatbelt buckle an see if that stops it.
I'm not sure about the menu system on your car.
Robert G8RPI.
Hi Romin. Suggest you have a look at the car manual, re the menu. If you don't have one download it from the forum. It's at the top under the forum heading.
It's too coincidental not to be something you did when you used the menu options.
Let the forum know how you get on.
On the GP the seat belt buzzer alarm function is only available with the engine off, but ignition on. But I wouldn't expect it to alarm without some one/thing on the passenger seat and the belt not plugged in. This option also disables the drivers bleep, but not the light.
