A few days ago my car cut out about 5 seconds after start up - puff of smoke came from the steering column. The next day I started looking for why this happened, obvious point of call - the fuses. My ignition fuse had blown so I decided to take apart the steering column and found that the culprit was the REM wire going to my amp that I had wired into the ignition switch (my HU doesn't send a signal down the REM).
Annoyed by no music I tried to get the amp running by connecting the REM to different power sources used for the HU, each time blowing a fuse. So I thought I would see if the amp would turn on if I connected the REM directly to the battery. This cause the REM wire to get VERY hot, glow and begin to melt the plastic insulation, so I quickly took it off (didn't connect it originally, just touched it on the + battery terminal).
Next I had the idea of looping the REM wire from the +12V on the amp to the REM. Again, this caused the wire to glow, get very hot and start melting the insulation.
So my question is this - Is my amp shot?
Any help greatly appreciated!
