No, the BCM cannot power the lamp, the BCM only puts out 30mA before decreasing the voltage
Well, yes this is what I was thinking too. I can 100% confirm there is no fault in the wiring because I ran a complete separate wire (one that could easily carry several amps without loss) straight from the BCM directly to the D+ pin, also did multiple resistance measurements over the existing wiring. I wanted it to be a wiring problem haha.To me this indicates BCM fault or wiring from BCM to L terminal
If BCM can't power a small bulb it is clear it can't power the rotor electro magnet.
We will know more when you receive correct regulator.
I did say that after installation of the original voltage regulator the problem was briefly fixed. I also measured the current then and I also read about 30mA. So the same current as always. @jackwhoo as @koalar pointed out, could it be that this type of regulator takes a very small current from the computer in order to wake up the IC and it then takes power from B+ to power the coils?
Anyway, we will indeed know more when the new regulator arrives.
I will measure the pulleys when I replace the regulator.
The information above description is measured from a couple of my alternator alternatorsWhere did you find this information? I'm trying to find datasheets/specs of the all the different regulators but I can't find much between all the webshops besides voltage rating.
Anyway I just ordered the same regulator as the original one, I missed it before but it's available on Amazon. Going to take some time though to get here.
This hopefully.If I didn't have so much time or interest in this issue I would have already put in a new alternator, LOL.
Does not 1.6V suggest two diodes in series. If one was faulty?????Ok guys, finally I got the package. There was some construction in my street and the delivery guy couldn't be bothered to make a 100 meter detour apparently...
So what I've got is a Bosch 1 986 AE0 120, but I ordered a F00M144128. It's listed as the replacement... Well, we'll see.
I'm not at the van right now but I took some readings.
Resistance between L/D= and GND is again 56kohms... Just like the Hitachi, uh-oh
But, I do measure a diode on the same circuit with a forward bias voltage of 1.6V. the old one (the one that starts the alternator at 1500rpm) also had a diode that measured only 0.6V. On the Hitachi there was nothing there. But I will take a last measurement before sending it back to where it came from.
So, with a bit of luck it stays dry and I'll slap the new reg on tomorrow. Going to try that without taking the alternator out. Not sure if it's possible but with a short screwdriver maybe.
There are rectifier diodes with that forward voltage. so... hard to say without schematics. I'm going to mail the store to make sure I have the right part.Does not 1.6V suggest two diodes in series. If one was faulty?????
Thanks Jack, that's what I found after a quick google as well. The GTIN is also the same.Part number
1 986 AE0 120
GTIN
4047026541885
Replaces number
F 00M 144 128 - BOSCH
Guess we are good to give this one a try then.
BTW: meanwhile the old regulator still holds up. Even if the BCM is at fault we should expect at least the same behaviour, right.
So amigos, the new regulator is on. I did it while the alternator was in the car. It's not too hard if you can get enough pressure on the philips screws. In my case they already had been off so nothing to difficult there.
It's now kind of fixed, but we'll see tomorrow, since last time it also worked for one day with the old regulator... (which is still magic...)
The engine still revs up a bit to about 1000rpm and then the alternator kicks in.
Voltage is stable across the rpm range and load (turned every electrical on and off)
If it behaves like this I can live with it.
I'm actually starting to think this alternator is not meant for this vehicle: it says IVECO on the label, it's an Iveco engine but an actual Iveco Daily might have a bigger pulley on the crank which gives the alternator more rpm. Although I doubt that scenario...
btw here a the dimensions of the pulleys: crank about 14.5cm, alternator pulley about 6cm in diameter.
