Technical Alternator not charging
storm634
UK
Hi guys, I have a 2007 Fiat Panda 1.2 dynamic and the alternator will not charge the battery. If I jumpstart the car it will run for a few seconds quite poorly and then the screen will flicker and cut out.. Before changing the alternator, I want to check out some other bits and after an OBD scan, it is throwing up a U1600 code. Could this issue be key-related? And what else should I look for before changing the alternator? Thanks
Model
1.2 dynamic
2007
Yes it would run fine if the other car were to stay connected, and when using a battery tester the light doesn’t come up on strong output, in fact it doesn’t light up at all.
Well I didn’t give the code a second thought until another forum mentioned it could be ignition key related and the key has been in water before..
U1600 is a common error on its own meaningless, you need to know what module is reporting it
Often crops up with prolonged cranking and randomly even on a fully working car
What dash lights are on at ignition on
What dash lights are on at cranking
Only bothered about the right-hand side of the dash
Engine check, oil, immo, battery mainly
Do you have a multimeter
I do have a multimeter, dash lights are as follows:
This is on ignition:
This is what would be on while cranking:
I take it the battery tester works on the good car
And you cleaned the tops of the terminals before testing, green scouring pad work for me
The dark oxides aren't conductive and can cause a fails nevative
Yep battery tester works on good car fine, with a light illuminating next to alternator strong output.. yeah terminals are OK, they were taken off not long ago to scour slightly
Ignition on is fine
But during cranking
Engine, battery, oil, should stay on and the rev counter should move up, oil will eventually go out with prolonged cranking, engine should stay lit until it's fired
Is it the same with the other car still connected
Put a test lead on the battery negative, the other on some clean bare metal on the engine block, don't use the lifting eye it's painted and not conductive
Measure the volts while cranking should remain below 0.2V
Without the jump leads
Test post 9
What's the voltage
Can I just ask where is post 9?
For a bit of backstory this panda is not on the road and therefore does not have a very good battery anyway, but when I used another battery the other day it just drained it so I know it’s not battery issues. Whatever Voltage I get will be slightly lower than usual because the battery is not very good
Cranking should show 300rpm on the rev counter it's not
The clock not reset
The lights in post 6 while cranking are the same as if there is a faulty earth
Which will cause the alternator not to charge
The clock not reset
Ahhh right!! Thats very interesting. Where should I start then?
This will test the main earth under the battery tray
Here's mine with a faulty earth
Part way down the page, lighting a test light
Can't use the forum at the moment it on a go slow
This is the video of the cars ignition when the key is turned. I’m not sure if the video will play just let me know
